Zomerset
- Apr 6, 2019
- Model of Z
- 2.8
I knew it was getting to that point and its been neglected for 12 months due to life circumstances. The quote is plainly outrageous, at least on some items. But I'm now teetering on the edge of deciding to sell up and forget it. I guess I might get a couple of grand for it on a good day, with the work outstanding? Personal plate is probably worth a couple of grand too I hope. I can get the car home by paying to replace one tyre (has a few days left on MOT and that is the only "do not drive" fault.
- Technical assessment shows the headlamp aim is too low (MOT FAILURE) - Both Front head lamp aims are incorrect and cannot be adjusted correctly. The offside front leveling device appears inoperable and needs investigation. We will contact you regarding any further required repairs if required £120.00
- Replace both front tyres (offside front MOT FAILURE) - The offside front tyre failed the MOT and the nearside front tyre is very close to failure and should be replaced at the same time. £268.80 we have quoted mid range Maxxis tyres
- Replace both front suspension rear bushes (MOT FAILURE) - once the suspension bushes are replaced, the vehicle will require four wheel alignment. Due to the vehicle's age, the adjuster bolts might be seized. If this occurs, we will advise you and quote any additional repairs required to complete the work. £538.58
- Replace nearside front anti roll bar link (MOT FAILURE) - £214.85
- Replace the fog lamp switch (MOT FAILURE) - this would have to be ordered in directly from BMW £95.66
- Replace nearside rear stop lamp bulb (MOT FAILURE) - £46.80
- Untwist nearside rear brake hose - £96.00
- Replace rear differential bush - This part would have to be ordered directly from BMW £422.75
