Exhaust on Z3 1.9 1998
jasecasecarr
Gloucestershire
Hi, I want to ask about my exhaust on my 1998 BMW Z3 1.9. The exhaust, have attached pictures to help too.
I don't know whether it's loud or it's normal. When I initially got it, there was a bit of rattling, which I think was maybe rust in the middle box , but that seems to have died down after some miles.
But I've got a couple of issues. I don't know, should the exhaust be this loud? And there is a little bit of bubbling when I had it up on the ramp at the rear of middle box. I just need to know if anyone can tell me, is this a custom exhaust? Should it be making this noise? Just some guidance really the I was thinking I could maybe then get it looked at. I would really appreciate any help thx
The Legend
Deceased
It certainly looks like it's had a replacement aftermarket exhaust system fitted fairly recently. Can you see a brand name on the red sticker on the Cat?
None genuine exhausts are quite often louder, a "raspy" noise compared to an original one.
jasecasecarr
Gloucestershire
Thanks for this I can't quite see it in pics and sticker ripped.. yeah I have another Z3 2000 and it is quieter the raspy sound is more like it I guess.. you think I should make take it to a exhaust specialist and let them give it once over.. I was hoping it's all good and the noise is fine and just make sure it's ok the bubbling I assume could just be patched up
Trevor /chedder
Is there a hole or gap. In the weld on the middle silencer,? Looks like something on the pic.
colb
Newport, South Wales,UK
jasecasecarr
Gloucestershire
Anyone know of good exhaust specialist then I'm in Gloucestershire don't mind travelling just so I can get it to have once over and fix any issues
jasecasecarr
Gloucestershire
Had it looked at today — was told it’s okay, but there’s a minuscule leak in the mid-box and a loose bit of the cat in the back box, causing a small rattle, which I don’t think can be removed or broken down. Also noticed the front exhaust bracket is missing. Does anyone know which part I’d need for that? Would exhaust sealant be a good temporary fix for the mid-box leak too?
